mix-used building wip
Hi dear community :slight_smile:
Here 2 wip steps of the last project. C&C are welcome!
Thanks in advance!
if your using the vray cam and sun/sky, you need to adjust the textures on your trees and people. They’re too dark.
70’ tall trees with 2’ long leaves…interesting. If you want thr trres to be more realistic. Seperate the leaves from the trees, make a realistic leaf/leaves and use the old leaves as a distribution object, then delete the old leaves.
mh
good idea, mikeh
My suggestion was to open your trees (Onyx, right?) in the modeler, and make the tree height it is going to be in the model. This way, the leaves are the correct size for the tree. Or, at least go into the modeler, and select miniature leaves. That way, when you scale up, they don’t get as large.
10x for the advises.
I will change the things for the trees as you’ve said .
C u around soon.
