Mixed bump problem...
I got an problem about the bump, maybe have anybody idea whats the good way to fixing?
I attached the render and the material setup, please check it for me…
I have the Corona alpha V5 version. Maybe this is not an a big issue in the daily users, but I’d like to fixing this mixed bump…
Thanks!
…here I made a new render, but it’s looks like the bump is working…
Any idea?
What do you consider wrong in these renders? The bump map is too blurry or the “fabric” bump is not visible? If it’s one of these then I think this may be caused by texture filtering. Try disabling it in textures’ parameters or in Corona (filter texmaps). If you may send this scene, then I could check if the problem is still present in newer builds. Btw, did you sign up for daily builds?
Well, Maru…Thanks your comment !
Now I’m trying the the alpha issue, and yes I tried to get the daily builds, but I don’t have a activisation key…:frowning:
Somewhere, in something tutorial I seen, if I don’t wanna make the blurry surface, like in the second render, than I have to setup the picture’s blur to lower. For example the blure let be 0,2 not 1.
In the VRay if I changed the bitmap’s filter, than the displacement was much-much faster…But in the alpha5…there is when I tried the displacement, only once I got a render…and after all the time got a max’s crash. :frowning:
I wrote about Keymaster, but today I felt I have to make new renders with alpha5 and learnig…learning.
I think this is the best render, and I like to learning…this is my passion! :smiley:
I’m addicted of Corona! :smiley:
There is huge difference between A5 and daily builds. Your problem is probably already fixed (although I’m not sure what is it :smiley: ). Just wait for A6 and you will be happy.
Thanks maru I’ll be waiting. Just I would like to make my portfolio with Corona and testing this really good render, and all the time make me crash in the bigger scene… :frowning:
