Im doing a mixing paint simulation in Maya, using PhoenixFd 3.0, i was wondering is there a way to control how the paint mixes/bleeds into each colour.
At the moment they mix/bleed well with red and blue making a purple colour but what im after is a slight bleed but with more of a marbling effect of the colours?
In this case, you are looking for the RGB diffusion parameter under the Dynamics rollout Note that in order to get this effect, you’d need a very high grid resolution. Also, please be sure to get a nightly from at most a few days ago, since we fixed a couple of issues with RGB mixing of FLIP liquids.
Ah, wait - since you are in Maya, a latest nightly will be out of the question for now, but soon we’ll have the official release which would include the fixes.
In order to render the wetmap, you need to load it into the Phoenix particle texture and use that as a mask for blending between a dry and a wet material: Chaos Docs
So, i brought the RGB Diffusion down really low, and the effect is kind of working, but i get a really dotty effect when mixing,very noisy, how do i get rid of this?
Is it the resolution?
Also when using the wetmap, how can i get the RGB of the paint to be in the wetmap at render?
You can get the RGB into the wetmap by using the Phoenix Grid tex to get the RGB of the simulator the same way it’s used in the paints preset, and pass it into the diffuse slot of both the dry and wet materials you use for the wetmap.
Nice! So hmm… maybe something is limiting the resolution. If you like, you can drop the scene to Support so we can see if it isn’t something that needs fixing…
Its just a scene i’v been playing with, so happy to get your feed back on it!
Also, if theres a better way to go about doing the initial setup for the simulation effect? Test.mb.zip (194 KB)
I’m sorry, haven’t been able to get to it yet - I’ve got a few more scenes to look at and seems like Support are a bit overloaded too at the moment, so it will take some time until I can get there.
