So if I’m planning on building a modest multi-GPU rig, what mobo can I get if my CPU is a Ryzen 2700X?
I’ve had a quick look and seem most of these only come with 2 or 3 slots for gpu. I’d probably only have 1 GPU in there, but would like to know I have the option to add more later
Looks like the X470 chipset boards are the new ones
the 2700X has 24 PCIe lanes, and in many Mobos 4 of these are used by chepset for things like M.2 and other devices
So you are only left with 20 PCIe lanes, on 2/3 slots
For optimal results you should run your cards at x8 at least, x4 will affect loading your scene into VRAM, but mostly you will be fine with 3 cards
X470 Boards are very cheap, I would recommend the Maximus Hero which is at 250 USD
It is probably the best/most expensive Board for this platfrom, and it should handle 3 cards without issues in future (x8,x8,x4)
If you want something cheaper, see the X470 Strix at 160 USD, but for 3 cards and considering how cheap boards are for this platform go for the Maximus Hero
I don’t think there is a board that has more than 3 full sized, PCIe slots for this platform
An affordable solution for 4 GPUs would be 1920X(very cheap now) and something like X399 Gaming pro Carbon
Or look for an i7 6850k and an X99 board that has 4 PCIe slots, but these are quite rare now
With TR, you will have up to 5 slots(with a specific Mobo), so you can fit 3 cards on Mobo and maybe use 2 Ryzer cables for the other 2 cards or just use 4 cards directly on board
On Intel’s side, X299 for example , you can have up to 7 slots and again you can only fit 4 on Mobo, so if you want to make use of all slots you will need riser cables(Anything above 5 cards will not work out of box, you will need to do some work)
Then with 2 Xeons, you can have up to 7,8,10 and 11 slots without the need for risers
With Thunderbot 3 support on some high end Intel Mobos, you should be able to use eGPUs(up to 4 through an external box)
There are more ways to run multiple cards, but I would not recommend, like PCIe clusters or running cards on x1 slots, things get complicated and there will be a performance hit
Threadripper 1900X >> 350 Euros
MSI X399 Gaming Pro Carbon >> 320 Euros
32 GB DDR4 RAM 3000 Mhz >> 220 Euros (must be 4 RAM stick for quad memory channel)
Be quiet Dark Rock Pro >> 80 Euros
Be Quiet Silent Base 801 >> 140 Euros
Be Quiet 1000W 80 plus gold >> 220 Euros
970 EVO 500 GB >> 110 Euros
Seagate Barracuda 4TB >> 80 Euros
1070Ti 8 GB >> 500 Euros
This should be cheaper than 2k Euros, so you still have money left for monitor, keyboard, windows and other things
And btw, no cheap parts as everything is within your budget,
this system can equip up to 4 cards whenever you think about adding more, you don’t need to change power supply
The RAM I used is 32 GB 4 sticks x 8GB Gskill TridentZ RGB @3200 MHz
not the cheapest RAM, but TR benefits from higher memory speeds and I have been using this RAM for many other builds. It works nicely
About the Case, it has a built-in fan hub like what you see in the first picture, and it comes with 3 Silent wings fans, which are silent and still has an amazing peformance
I dislike RGB, and I’m not willing to waste my money on it really .. Same fans in the case, are used on the CPU cooler, the Dark Rock Pro 4.. I have used this cooler in many builds, works nicely/silently and you can overclock with it to 4 GHz without issues
Nope, I have done 4 GPUs on variety of Mobos including this one
you can place a card in there, on top of the cables, the cables will bend slightly but you should be totally fine(MSI knows about this issue and solved it long time ago)
This last slot actually allows you to use bigger cards, (more than 2 slots in width) without issues as there is no other slots below it
So it is very common that people use this slot specifically even if they only have 3 or 2 cards only
Worst case scenario if you are not confident to place a card there, you can live without the headers at the bottom
They are for USB 3/2 and HD Audio for the front ports on your case, and header for your AIO pump/RGB stilpes which you will not use as you will be using an Air cooler for CPU
What you will need is headers for start/reset buttons which is way to the right at the bottom
