model / geometry disappears
When i render (using corona renderer) the whole scene (geometry or models) disappear, only HDRI appears
If your render is completely white or pitch black, it could be that you have issues with lighting and/or exposure. In any case, it’s hard to tell anything specific with so little information that is provided. Can you at least attach render result that you’re getting and the screenshots of your render setup?
Here they are
Just FYI: “PrintScreen” is a very useful feature available on your keyboard
Here are my suggestions:
  1. Upgrade to Corona 11 HF 1.
  2. Check if Camera clipping is not enabled in your camera.
  3. Check if the object properties of your object are set to renderable.
  4. Check if you are not rendering the wrong camera.
  5. Check if the camera target distance is not set to 0
If the above suggestions do not work for you, it will be better and faster to submit a ticket at: https://support.chaos.com/hc/en-us/requests/new
This is now being handled in this ticket: #208222
Nothing worked
Hey,
I had sent you an email on your ticket asking the info but you have not responded yet. Can you please reply to the email so we can help you further?
