MODERN RESIDENTIAL '"douglas"
C AND C’s ARE WELCOME
Re: MODERN RESIDENTIAL '“douglas”
i think your image is preatty fine, but it’s sort of low resolution :smile:
reflections on the last two images seem to be too much, maybe you need to decrease a little the glass material. or just import one of the glasses from the vray materials
thx a lot dude.. :stuck_out_tongue: ok ill do next time. yes low resolution 600X800 .. its because the high the resolution the more hours it would take .my pc is damn slow
hehh, i have had that same problem.
it’s looking good anyway.
have you tried copying somebody else’s visopt?
i don’t know if it is beacuse of the low resolution, but i see some noise, and crispy edges… also a little bit of too much ambient oclussion
Hi, good renders, I like the first one, because of the grass :wink:
Try to improve some materials :wink:
hahahahah .thx for the comment guys i usually use 600X800 .next ill reduce AO. and i use the veri good exterior visoft. i just save it jpeg thats why it has noise. my bad :frowning:
I think that materials needs a lot of work, water looks like mercury, plants looks super low res. sky looks too flat, contrast some textures by adding some dirt on them so they dont look so perfect. etc…nice try anyway. :slight_smile:
OMG its teofas . Ok dude ill keep your word its because it helps me to reach next level :slight_smile: thx a lot really. and like you said ill edit materials well :slight_smile: and need a nice resolution in plants, :wink:
http://www.megaupload.com/?d=5OMUH7KA heres a link for the water vismat bro, this is the one i use, just change the bump multiplier and the diffuse as you like, hope it helps.
thhhx a lot brother :smile:
