I’m hearing very good over Corona Renderer and then decided to test.
Scene modeled in Modo and rendered in Corona.
My first scene and will be the first of many, Corona is very good.
Artur, you can literaly count the pixels on your floor texture aswell as on the wall. You are either using some sort of box bump map or we have a bad case of texture resolution.
Also your chair is a bit too saturated its 2,2 not 1
Thank you!
On the wall I wanted to cause the relief effect.
About the floor I could not get the texture, I’m new to 3ds Max
Really the texture is low resolution because the UV in Modo was correct.
The chair I’m using the same 2.2 and yes, this saturated
