When Using the Mograph cloner object, and set the cloner object mode to “Object” - the clones are not showing when render to IR.
I confirmed this in 3 different scenes.
Kobi
anyone else can confirm this issue ?
I think the problem you have comes with the Instance Mode “Multi-instance”. Change it to Render-instance.
There are still issues with Multi-instance in IR.
Thanks, I’ll check that
Also, make sure you check by rendering to both IR and VFB as I have seen different behaviour between the two when using cloners.
There are definitely issues with cloners and the different instance modes and you get different results depending on whether it is geometry or lights you are cloning and depending on what you are rendering to (IR or VFB).
Thanks for the tip
Yup, multi-instancing isn’t fully supported yet. IR doesn’t show them, final rendering does.
I know its probably not what you wanted to hear but … ![]()
