Monitor 4K & Crona VFB pixel size
Hi guys!
I notice a small bug here while using 4K monitors where the size in pixels of the real rendered area in the Corona VFB is not correct. (I love working lately with 4K monitors btw).
How to reproduce:
  • Hit Render button.
  • Render a 1000x1000 pixel image. You should already notice that the render area is smaller than it should really be.
  • Hit Stop render and then > Max (copy image to 3ds Max VFB).
  • The 3ds Max has the correct size now while the Corona VFB didn’t.
I use 3ds Max 2017.
Please let me know if you notice this problem too.
Thanks!
Dionysios -
Thanks for reporting! We have some hi-res UI tweaks planned, so this will be probably fixed soon.
Thanks for getting back! :smiley:
BTW, today I installed to my home workstation the 09/01/17 build and the situation got worst. During the IR mode the render area is always set to 502x502 px. Whenever I try to scale up it turns back to that value… :frowning:
duplicate: 4K support is planned: corona 3d max and windows scaling on high resolution monitors - Corona for 3ds Max :: Requests - Chaos Forum
