Monitor Calibration
Hello all,
my images look too dark when I give to the client. How can I calibrate my monitor?
Even with gamma 2.2… still too dark. And when I am Photoshoping, 2D work, same…
Regards
Srdjan
In order to calibrate you monitor you’ll have to by a “SpyderPro” or similar.
Hello tct70,
sorry don’t have any clue, is that software, hardware, does it comes different for the specific kind of monitor, where I could get it?
Huh, :roll: , too meny questions :wink:
Regards
Srdjan
It’s hardware for any monitor fella…google it, should give you a list of retailers in your patch.
Hi tct70,
Thank you so much, some shops are selling it here :smile:
Regards
Srdjan
You’re welcome. :wink:
Just another quicky,
it comes in three “flavours”
1.Spyder2Express
2.Spyder2
3.Spyder2PRO
is Express good enough? Because prices are very different
Regards
Srdjan
if you only have one monitor then go for the middle one. Express won’t be good enough.
I got two monitors, can’t you calibrate two monitors using the middle one?
Pro for two monitors.
Thanks mate!
I would look at the huey , dual monitor support pretty good Calibration software and a good price http://www.pantone.com/pages/products/product.aspx?pid=550&ca=2
Hello RErender,
Actually, I got 2 monitors, attached to two different computers, not dual monitor :sweat_smile: that changes everything :roll: :?:
You can use the spyder 2 (middle one), for dual monitors.
You just need to calibrate each monitor separately by changing which monitor is the primary one. Then use win color to load each colour profile during boot-up. Works a charm here :slight_smile:
Hello jow,
thanks for the reply!
Just now I have ordered Spyder2, middle one, getting it tomorrow :smile:
thanks a lot to all guys helping me!!!
I’ll be Spyderman tomorrow 8)
Regards
Srdjan
Spider Pro
I have a Dell widescreen LCD. Is this he correct calibration device for me?
That should work fine but there are others out there: GretagMacbeth EyeOne Display2, Pantone Huey, etc. I’ve got the i1 Display 2 running on my Dell 24" and it works great. Prints from my printer and labs are pretty close to the screen(close enough that I wasn’t suprised) maybe a little darker, etc. but I didn’t have a profile for their printer either.
Just a caveat that I learned the hard way. I have a Spyder too and love it. It does a great job. But dual-monitor support has more to do with your video card than the Spyder. If your card/driver won’t support a *separate* profile being loaded on each monitor, NO calibration hardware will help you.
So, either use 2 video cards, or make sure your dual supports independent profiles.
I just use this -
http://www.microsoft.com/windowsxp/using/digitalphotography/prophoto/colorcontrol.mspx
