Monitor, Max, Windows, or VRay 3 Menu Glitch
I think you are right - this is not related to Vray directly. It is either 3DSMax or drivers issue.
Have you got the same behavior with another applications?
What happens if you are using the same resolution for both monitors? or switching the Main Display to the new monitor?
Have you tested another GPU/Monitor drivers?
