Moon issue while using physical sky
I was trying to use the moon option in the physical sky mode, but it only shows up when the sun is checked… When I turn off the sun and go to moon settings, as soon as I adjust the brightness slider, the moon disappears. What’s the proper workflow for the moon and stars?
I’ve noticed that when the “Invisible” option is checked in Sun, moon automatically becomes invisible.
Ooh… interesting. But you would still get the brightness generated by the sun. So does one turn down the intensity?
Hi guys,
This sounds like a bug to me an I will log it. For the time being I would suggest a couple of workflows:
  1. Full Geolocation
    • Enable Sun and have Sun position mode set to Geolocation or Animated Geolocation. Adjust the geolocation and time as needed.
    • Enable the stars and Milky way and have the Stars position mode set to Geolocation from sun. Adjust the brightness, star size, etc. as needed.
    • Enable Moon and have its Moon position mode set to either Geolocation from stars or Geolocation from sun. Adjust the brightness, size, etc. as needed.
      • With this workflow you can have a full day-night simulation with just animating the sun
  2. Manual
    • Enable Sun and have Sun position mode set to Altitude/Azimuth. Set the Altitude close or below 0.
    • Enable the stars and Milky way and have the Stars position mode set to Geolocation . Adjust the geolocation, time, brightness, star size, etc. as needed.
    • Enable Moon and have its Moon position mode set to Altitude/Azimuth​. Adjust the position, brightness, size, etc. as needed.
      • With this workflow you can have a full control where each element is in the sky for composition.
Yes, the advanced options and exclude/include lists are affecting both Sun and Moon.
Alexander
