With almost every update, it seems that more 3D assets are added to the library (which is great!) but I can’t recall more materials being added to the material library (if I’m wrong please correct me.) In any case, adding additional materials would be greatly appreciated, you can never have too many options to choose from, and it makes the whole workflow easier by using enscape materials instead of fiddling with the host program’s material editor.
As a second layer to this (and this is still probably a little ways out technology wise) I would love to see AI generated materials that can be updated in real time, and has a type interface. For example, I could pull up the menu, select the wall I want to apply an AI material to, and then type in “brick wall” and it would generate a texture based off of my text. What would really make this feature amazing is if after the initial request, you can make additional requests like “make the bricks smaller”, “make the bricks more red”, etc. This would revolutionize how materials are applied and would be such a time saver.
Submitted on AHA Ideas by Jacob Levy (ENSCAPE-I-1522).
