-1,2 aint gonna cut it for animation. you need to suck it up and use minimum 0,2. I can’t think of another thing to try, except video filter, but thats really going to soften the entire frame.
i ain´t sure either , but i m betting on AA so far…
those brighter pixels r harder to deal AA-wise, so they r the problem to tackle…
are they contributing to direct lighting?if no just hide them and test if there occurs no flicker…
percydaman -1,2 aint gonna cut it for animation. you need to suck it up and use minimum 0,2.
ts taking between 5 & 9hrs a frame so i can’t up the AA at all. For the rest of the scenes i have reduced the size and glossy settings so i might be able to increase it for them
ene.xis
I’ll replace the Vray light mats with something duller and see if it helps.
5-9 hours a frame!? That’s crazy for something like that… what kind of computer are you on?
I usually try to make sure the vraylightmtl objects are just over 1.000 in the rendered frame window, anything brighter and the AA gets a bit more difficult. That said, it has to be the undersampling that’s causing this, I think you’ll have to do 0,2 to fix it.
The quickest way without increasing rendering times would be to isolate the vraylightmtl objects and render them out seperately with higher AA settings. Then comp this over the existing animation.
Tell me about it it that frinkin bookcase or the bookcase ends to be precise , 2 layers of transparent frosted (glossy) plastic with a overlayed graphics. the only way could get it to look like the designers wanted it was to build it as it would be built. :x I have since refined the sub divs and glossies & got them to render about twice as quick for later scenes.
I’m sure my vrylightmats are set to 1 or 1.1 no more anyway.
Its rendered at 1024x576 and i’ve got a P4 with 4Gb ram butmost of the render nodes are P4’s with 512Mb Ram.
What are your render settings.. speciaically your IR map settings. is the clr thres below 0.3? if so that would be killing your render times… but man P4’s with 512mb ram :shock:
Get one quad core and replace all those machines hahaha.
Also your back ground looks bad when the camera moves as the sky map is set to screen mapping
My IR settings are
Min -4, Max -2, HSph 35, Interp 25.
Clr 0.4, Nrm 0.3, Dist0.1
I have precalculated LC & IR maps but there is quite a few standard spots so as i understand it they are calculated on a per frame basis.
The sky is a still i added in post using premier. Have you any better solutions?
4 Core 2 duo’s arrived the other day to start a dedicated farm with 2G ram in each so when my dongle arrives we’er upgrading everything to RC3 and hopefully bye bye 9hr render times.
Thanks for your input do you still think i could i prove rendertimes through IR settings :?:
Those settings seem ok. Nothing to crazy there.
For your glossy materials make sure your subdivs are not too high… i.e. under 20.
For the background, best to do it in 3dsmax, if you have a 360 map just apply that the env with a spherical mapping type in the material editor.
If the camera is moving using a single image is bound to look crappy.
I have some 360 sky panos that you could use if you like.
www.apex.net.au/~daforce/www.1000skies.com/fullpanos/images/
The are not all that high res but might do the trick.
Do the lights flicker if you dont have the vraylightmtl there?
Might be worth while doing that as a seperate layer and combining in post or just do the glow/white parts in post.
I’m not sure i can handle rerendering with the background in max but i’ll put a map in the environment next time. i just presummed you got more flexability adding it in post.
I have little experiece on post production but I’ll try rendering just the vraylightmats and add them in. The thing is the lights show fine in the rest of the scene
Yeah the sky looks really bad when done in post that way, not to mention physically impossible
Adding it in 3dsmax will look alot better.
You can add the sky in post when rendering stills that fine, but as soon as you have camera animations it really needs to be done in max.
Adjusting the dist threshold might help. but that will affect the IR map, as others said the problem you probabaly having is with AA.
For a test try rendering those few frames were it flickers with QMC/LC just to rule out it being a IR map problem.
This is a really, really small scene and there’s no reason why you can’t render each frame in less than 10 minutes. Also, adapt subdiv may be possible with this scene but by no means necessary.
You really should consider using the video filter for most animations period but you can certainly remove the flickering with good image sampling. I can’t tell from you’re previous posts, but if you aren’t using a saved irradiance map and light cache, then you must.
I also recommend a 3D background rig for your scene. I use them for every scene. Might want to check out these tutorials (week 6,13, and 17) http://3dats.com/tutorials.asp
It’s part of a much larger animation rendered for HD. I am reluctant to split it up as the rooms are linked with glass walls and the designs seem top change on a weekly basis so i don’t want to have to go round updating numerous scenes. The file has about 1.5 million polys and Memory usage of 800Mb according to the Summary info. not sure if this is considered large or small.
I have save LC & IR amps as mentioned above. I have rerendered a background and will add it in post. Thanks for the links to your tut i shall have a look at it asap.
I tried the video filter on other scenes but it softens everything so much you start loosing too much detail.
I’d be very surprised if you could render this in 10mins :lol:
looking at you scene and render times I think you must be able to optimise this scene greatly…
looking at the overall lighting, I think you could change something there.. what lights are shdow casting? where are the vray lights? are they really neccessary, I know I could create a similar lighting set up without vray lights, just some well places standard lights and vray light materials (for the halo light etc)
you say you are rendering for HD… is this where you are getting your 5-9hr render times?
all for using vray glossies, but I am finding it hard to see them in the scene with a more standard material for the desk screens with a simple opacity fall off im sure you could get 90% of the look with massive rendertime savings.
also, I can see that the GI looks a little strong, over saturated, alot of colour bleed from the desks bouncing up onto the walls… maybe reduce the GI saturation level too..
are you pre calculating you LC and IRR map every 20th frame or so?
p.s hve you tried disabling the AA filter altogether?
sorry but i think you’re going to find a lot of flickering when not using a blurred filter…just the way it is. if you render in high def and convert down, your video filter will have the look of the area filter in the final animation. if you move the camera very slowly you can get away with the area filter or something else less blurred. and yes, you can get 10min render times for your scene. i would post all of your settings so we can see what your doing…and of course make sure you have all materials set to vray and non-vray shadows.
i’m not a big fan of the video filter, would prefer to render at a higher res and sample down. I sometimes use a sharpening filter in Post (combustion/after affects)
i think this will be a good thread if we look at the scene optimisation!! and help cut the production time of alot more of your animations..
