Morph Camera and DOF
Hi
I have a morph camera with two sub-cameras. The sub-cameras have a camera tag with DOF. But this will not be rendered. Does cameratag not support morph cameras? I have tried it with R21 and S22 with the latest build.
I found the same problem in this forum for octane:
«Camera Morph is a C4D level tool, and it doesn’t know anything about Octane Camera tags. Notice that the Camera Morph tool actually creates a completely new camera, and that camera takes its info channels from the basic C4D camera data. Camera Morph just doesn’t have the hooks to pull info from Octane tags. »
Is this also the answer for corona cams?
Hi there, I haven’t used this Morph camera before but it seems to be working for me. I have added my test scene for you to go over. I hope that helps!
Vide example: https://streamable.com/tltayp
Morpha camera test.c4d (181 KB)
Thank you, Bengamin, for your efforts and the test scene. That’s interesting. I actually have very similar takes on my scene. I’ll check that again. At least this proves that it’s compatible with the morph camera. That’s a good thing!
You’re most welcome!
