hi folks, i need your help making this mosaic material, or if someone has one already, id ge grateful if u cud share it. thanks in advance.
try brick map and “Stack Bond” preset.
could you explain?
regards
S.WOlf
most drawing packages have a mosaic effect that can be applied to an image. Simply create your design and apply the effect. Use the finished image to creat a bump map.
