I moved this topic to this section, after not getting any respond and Im sure that is an issue.
It works more or less in real time (with artifacts and wrong amount of MB) but in offline it dosent work at all.
3090 + 2080ti (457.09)
Hi Paul
Sorry for the late reply.
You are correct, it is a bug that is occurring when utilizing 2 GPUs. Can you please try to use using just one of the cards to see if the issue persists? You have to do a manual set up for this at the moment. Start Vantage like this
vantage.exe -d 0
to use the 3090 or
vantage.exe -d 1
to use the 2080 ti.
You could also use this argument in a desktop shortcut for easier use.
Alexander
The issue with dual GPUs will be fixed in the next Vantage update.
