motion blur issue with multiple objects overlapping
I have a scene with a helicopter that has 2 rotors on top. When the motion blur is on and they overlap at certain areas i get a black line going through it(see attached) Its not always there, just seems to happen when they overlap just right, has anyone seen this issue before?
Try increasing the motion blur’s geometry samples either globally (Render setup>V-Ray>Camera>Geometry Samples) or on a per-object basis (right-click object>untick Use default moblur samples>Motion blur samples) and see if that makes any difference. If not, do send a stripped version of the scene via the contact form so we can take a look (mention the animation frame where the issue is present). Address it to me in the subject and include a link to this thread in the message.
i sent you a message/3dmax scene via the contact form, example frame shown here is 114 which highlights the issue
Just to inform you, we are investigating the scene. I’ll write again whenever there is more information.
