Motion blur not working on meshed fluid sim
Motion blur not working on meshed fluid sim.
I have velocity attrib but I am getting no motion blur and / or no RE velocity pass (well its rendering blank)…
Any help appreciated
Hey Jim,
Could you please check if the Geometry node → Render → Sampling → Geometry Velocity Blur is set to “Velocity” ?
Best regards!
How embarrassing :slight_smile:
One more question if I may…
How do you calculate what the max velocity or velocity range should be in the RE_velocity pass ??
it seems arbitrary or do you just save as 32bit and it just works?
Hey Jim,
Indeed, if you need to clamp it, I can’t think of a way for us to handle this automagically - you’d need to set the Max Velocity manually.
Best regards!
OK so if I am saving 16bit exrs how do I approach that setting? What are the units? Is it the magnitude of the vector as accessible in Houdinis geo spreadsheet?
