Motion blur not working with the USD stage - Vray 7 update 2 + max 2026
Hello everyone!
I’m having the issue rendering the frame with the motion blur with the USD stage.
To be more precise: I have an USD asset loaded as the Max’s USD stage. That asset has been linked to the point helper which is animated. Very basic setup.
When I try to render the frame with the motion blur, it’s not working. No motion blur is rendered. I’ve tried to load the same asset as the VrayScene, but I’m getting the same problem.
I’ve even tried to animate the USD stage on it’s own (without parenting it to the helper), and I get the same problem.
Normal (any native) 3DS Max geometry is working correctly.
I’m using Max 2026 and Vray 7 update 2 at the moment.
The thing is that I’m not 100% sure, but before I did the upgrade from Max 2024, Vray 7 update 1, I didn’t have that issue. But, I did a tone of testing before that upgrade and I really think I was getting the motion blur render correctly.
Any idea what could be the problem. Is it a bug, update issue, or unsupported feature?
thank you all in advance!
all the best
It’s probably not yet supported. I’ll ask the devs. Otherwise, if the animation is within the USD (and exported with it), motion blur works correctly.
yes, in this case the animation is made within the USD. So basically I have a helicopter USD asset with animated propellers, and it’s not working on my side, it’s rendering without motion blur.
Even if I take any USD asset without embedded animation, and animate it on my side, it renders the frame without the motion blur.
And I repeat, I did lot of tests with Max 2024 + Vray 7.1 before the update and if I remember correctly I was getting the correct motion blur.
Works fine on my end (a scene with embedded animation) with those versions. Which USD version are you using? Make sure it’s supported.
I’ll log this.
Otherwise, best you send the scene so we can troubleshoot.
I’ll do that so you can try on your side and try to troubleshoot.
thanks a lot for the help!
I asked because you may have another USD version installed. You can check which one you have in Windows’ control panel or in the plugin options in 3ds Max. Otherwise, do post your ticket number whenever you send the scene.
thanks,
the version is 0.12.0.13
I submitted the scene and here is the ticket number
Request #412318
Thanks again
Actually it does work with the embedded animation on my side, I cleaned and re- exported the scene and tested again, but with the linked USD asset or animated USD asset it’s not working on my side
thanks!
You mean linked to the Helper, right? Yes, as I mentioned, this didn’t work for me either. I’m going to report it asap.
Otherwise, thanks for the provided USD - as you’ve already found out, moblur works fine when embedded in the USD itself. I guess you missed something when exporting.
You’re welcome. The drone USD asset is very simplified proxy model I use for animation purpose.
I cleaned the scene for this purpose and re-exported only needed elements for you, and imported back again in the Max it worked with embedded propeller animation.
I’ve also tried to embed entire animation drone+propellers as the USD, bring that back as the USD stage and it worked too.
But linking just the USD asset to the animated helper, or animating the USD asset directly didn’t render with the moblur, as you saw from my scene. There’s only the moblur visble on propellers (as this animation is embedded) but entire drone’s body remains without moblur.
Thanks again for the help
Actually, I forgot something new to USD 0.12 - you can promote USD prims to 3ds Max objects. If you open the USD Explorer and promote the body (RMB on prim > Promote to 3ds Max object) and each propeller (must be done for each, else the animation won’t stick), motion blur will appear as you would expect. This is probably the reason why animating the USD scene itself doesn’t have motion blur. When trying to compare the behaviour with Arnold, I get a crash, sadly.
Otherwise, according to the Autodesk docs, you can send back the adjusted prim back to the USD, but for some reason, I do not have that “Duplicate to USD” quads option, but this is a different matter entirely. EDIT: Nvm, I was with an older USD version.
Yes I saw these two USD 0.12 options, nice stuff indeed. This could be the heavy workaround to get the moblur working at any cost, but for the normal workflow it’s the nightmare. It should work natively.
Btw, I’ve tried Arnold too, but crashed on my side as well. Probably it should be used with Arnold’s USD objects, and not the Max’s USD stage. But, in that case, all exports back as the USD stage, with changes, animations etc, I don’t think it’s possible
Okay. Tried with Arnold USD Geometry, and it indeed animated USD scenes do get motion blur. Logged an issue to work on our end too (internal tracker ID: VMAX-15178 ). For now, the promote workaround is the only way it seems.
Just to mention, it should be tested and fixed using the USD asset within the VrayScene as well, as there’s the same issue with the moblur as with the Max’s USD Stage.
and one quick question: this “internal tracker ID: VMAX-15178” means I can track the process somewhere, or it’s just as the note for you?
Noted.
It’s internal. I’ll write again whenever there is movement on the case.
thanks again!
just another 2 notes:
- As you already flagged the motion blur issue we discussed, then the camera motion blur should be also checked and verified that it works correctly
- Vray properties are not working with the USD stage. When I try to override any of those on the USD stage asset, it’s totally ignored. When I work with the USD asset loaded in VrayScene, then it works correctly.
Of course.
This is already logged as (internal bug-tracker ID: VMAX-15022). I’ll add a bump on your behalf.
great thanks!
