Motion Blur on a Still?
Hi Forum,
what settings do I need to see Motion Blur on an still Image?
I’m trying to make some stills with a Helicopter but I can’t see any Motion Blur.
Hey, Rick,
There are a few options, but in your scene, I recommend using a V-Ray physical camera. Within the Motion Blur Tab, you should enable the motion blur option and change the Rolling shutter option from disable to top-bottom, etc. The motion blur is visible in the bucket mode or final render. You can control the blur option via camera aperture option such s shutter speed or artificially by adding V-Ray object properties to moving objects and enable override motion blur samples.
Cheers,
It works.
Thank you
If you are interested in the comments of this video I’ve posted some setup information for helicopter rotor spinning and shutter speed: https://www.youtube.com/shorts/hh16F\_Xfqhs
@sirio76 Thanks. This helps a lot.
