Trying to reproduce a scene of a moving piece heavily motion blurred an lit with a strobing light.
This gives a linear pattern with more and less transparent parts.
I have tried to simulate it with strobing lights, strobing light material and an oscilating visibility but all seems to be ignored in my tests.
Is this a known limitation or am i missing something?
I think you get this effect when your camera is Filming with Low Shutter speed or Low frame rate.
You could create a similar effect with after effects Motion blur when you set the motion blur samples to a low value. Its not 100% accurate like in your picture but the same effect.
I don’t think this is going to work, V-Ray will always render a very smooth Motion Blur result no matter how low the Shutter Speed is.
The only way to get a similar result would be to duplicate the object a few times and make each copy offset +1 frame from the previous copy.
