Motion Blur
Doing a flythru animation and want to get some motion blur on the objects. I turned it on in the camera tab and set some of the settings higher and there is no motion blur at all. Set the duration to 4 with no change. What is the secret?
Motion Blur is currently not supported for V-Ray For Rhino.
Will it be available in V3?
SHoutzager,
The limitation isn’t on the V-Ray side, it is an issue of getting the object/cameras paths from Rhino to V-Ray. We are looking into adding limited Bongo support to V-Ray For Rhino which would then allow for motion blur.
Is this the plugin you are using for Animation?
But we shouldn’t forget the Maxwell plugin support it since a very long time for still images (independent from Bongo).
It boggles the mind that there are buttons that don’t do anything. And spot3d doesn’t mention that the feature is unsupported. You could play with a variable for hours, with no effect, and have no idea. This is madness.
could you please just grey-out all the unsupported features in the next release please?
Yes I am using Bongo. It is sooo much better than the built in animation tools in Rhino.
