Motion Inertia Rendering Problem
I am hoping someone help me with an issue, I am not sure if its a bug or something simple I have overlooked.
Basically I have a phoenix FD container linked to a missile to create a trail. The simulation works great but does not render when I go for my production render.
however, the simulation does render fine when I use single iterative renders.
I found that the only time the simulation does not render is when the container is moving in the scene, so when I unlink it from the missile it renders fine again in production rendering.
I cant figure out why phoenixfd will not render when the container is moving.
Phoenix 4.20.00
VRay for 3DS Max 2021 5.00.5
Windows 10 64bit
No error messages that I know of, just black screen renders.
Cheers
Hmm, do you happen to use V-Ray GPU or IPR, or is it a regular production CPU render?
Hi Svetlin,
This is just using regular production CPU rendering.
Another thing I forgot to note is that I tried rendering with Vray GPU and it renders fine. But in this case I do not want to use GPU rendering.
Would it be possible to send over a scene so we can make it happen here as well and figure it out? Indeed not sure yet if it would be an issue with the setup or a bug…
