Does anyone know of a tutorial that goes over the rigging of a motor; basically the crank, rod, and piston? I know there are ways to rig this thing so that all you need to do is spin the crank to get all of the pistons to fire.
I have checked out Elf’s rigging/wire parameter tutorials and a few others but just can’t get it all rigged up to work correctly
If anyone is up to the challenge (probably something simple to most rigging folks out there) and/or would like to help out let me know and I will send you a link to the motor.
Elf - You’re the BOMB!!! I don’t know what the hell my problem is, guess just inexperience at rigging Everything you have here is PERFECT, but I can’t seem to figure out how you have it all wired/rigged up. I can see how you have it all linked, but what is the correct way to see the wire parameters? It doesn’t look like any Animation Constraints are used in this, correct?
i dont know why but when i put on cam studio it screws up alot of stuff on my computer which doesnt end even with an uninstall and usually leads to a reformat.
Are you using the old 2.0 version or the newer 2.01 version? The newer 2.01 version has less features and is crappy apparently. Stick to the 2.0 version.
