Mouse dragging for value change
I struggle with some minor issue with changing of number values in vantage.
When I edit values e.g. Film spped of Camera (ISO) I often use click&drag by mouse - up/down for detailed settings. But when I drag mouse over the top border, cursor jump to bottom, but the valueas are not changed smoothly. It skips about of 300 /e.g. from ISO 1300 right to 1600/.
Downwards the cursor simply wont go over bottom border.
I am using live link with Rhino3d. Maybe it is interface issue but I like to use that drag feature in rhino, where I can drag mouse all the way up&down and values are changed fluently. :slight_smile:
Thank you
Do you have a multi-monitor setup, or a remote desktop connection or some other unusual setup? The spinners work smoothly for me (even on a secondary monitor with unusual positioning) and I assume for most other users, since we haven’t heard of this issue before.
Yes I have 2 monitors. It happens on my secondary monitor. Maybe could be problem their resolutions or something else?
My work monitor has 1440p and secondary has only 1080p.
Hm, I think I know what’s going on. It wasn’t happening on my secondary monitor because it’s vertical and therefore vertical resolution is larger than that of the primary. Seems the issue occurs when it’s smaller than the primary. We will probably fix this with the next patch.
:o These are very great informations…thank you for great support.
