Move Visual Settings into CAD Window
Status: planned
The Enscape Visual Settings menu should be moved into the CAD Window. This would allow for easier troubleshooting if an issue is related to settings or rendering quality that can’t be corrected if the user cannot open Enscape.
The tool should also display how much VRAM a specific setting or combination of settings will use prior to starting the Enscape Viewport based on the installed GPU, much like modern video games (GTA, Far Cry 3, Fallout 3, etc.)
Submitted on AHA Ideas (ENSCAPE-I-1459).
In the latest Enscape version, we already have settings for automated resolution and automated upsampling that should be helpful for the same scenario.
Do you think they are sufficient or would settings for the quality have an impact on other factors?
Submitted on AHA Ideas.
While automated resolution and upsampling are somewhat useful, this more focuses towards ease of troubleshooting in cases where Enscape fails to start, at which point you have to manually edit a text based file to change settings.
This also allows users to decide their quality settings prior to starting Enscape if they choose to, which is useful in Enterprise environments with potentially weaker hardware or in instances where a Project Manager/Director may advise or require specific settings be set prior to rendering.
Submitted on AHA Ideas by James Hollaway.
Instead of duplicating our settings, would it also be helpful if the quality settings defaulted to “Draft” in case of a crash to make sure to have a flawless startup?
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
