This is the same image, taken several minutes apart.
When switching to another view and then returning (for example with a batch render), the clouds are positioned differently.
This sometimes causes major differences for the overal lighting, reflections,… Sometimes even untill there’s no direct sunlight.
I work with view management. Every enscape scene has its own visual setting, so normally these clouds shouldn’t move when returning to the scene, since their location is determened with the Sky: Clouds setting.
Why is this happening?
Yes, latest version of enscape
Yes, latest driver update
Yes, latest sketchup version.
The reason why this is a problem, because we make about 80 pictures from the building with batch render, replace it with an alternative version and render again. (Up to 4 times)
When placing the four (same) pictures next to each other, the lighting is off and the actual differences between buildings dissipate.
Hi @Kevin_s_design_studio
I can imagine this is problematic.
I have just tested this on a small scale in our latest release.
Could you verify that your Wind Intensity setting is set to 0% in the Atmosphere tab in the Visual Settings?
As I only had this same effect when I left the Wind Intensity on, which with every render will influence the clouds slightly as well.
