Nothing to explain here - moving vdb or changing settings very slow, looks like reload each time
And the problem with the visible bounding box still here - with global volume or inside/intersecting with another object with volume mtl.
Some more explanation would be useful ![]()
Are you able to send the VDB in question to us? If possible in a simplified scene which shows the issue with slowness.
The second issue we are aware of and have it logged in our system.
Rowan
(Internal ID=594075946)
(Report ID=CRMAX-264)
I thought it was pretty simple, but ok
I have cloud VDB loaded in corona volumegrid, it takes some time to start IR. After that I can move/rotate the camera and everything runs smoothly. But if I try to change the position/rotation/scale of corona volumegrid during IR it takes a lot of time. Same if I try to change some settings like scattering or absorption.
Just checked - 7 seconds for a particular VDB file. So if I try to move it or change the scattering scale I have to wait 7 seconds each time. And max is locked during those 7 seconds.
I can send VDB but I see no reason for that - it behaves the same with any VDB. The bigger grid (amount of cells) - the bigger lag.
Checked with Pixar cloud (I think you have it) - wdas_cloud_sixteenth.vdb runs smoothly, wdas_cloud_eighth.vdb a bit slower, lag is quite visible on wdas_cloud_quarter.vdb, wdas_cloud_half.vdb - 5 seconds to refresh IR, wdas_cloud.vdb - 13 seconds.
Hey,
I have some good news, we’ve managed to fix this in v7 and it will be in the next daily build.
The other issue you reported we are still investigating and I will get back to you when there is some more information.
Cheers,
Rowan
Bounding box issue fixed: https://forum.corona-renderer.com/ Corona Renderer 7 for 3ds Max - Daily Builds Changelog #msg182024 ![]()
I just checked out those Pixar cloud VDBs.
I guess it is to be expected that the larger VDBs take longer to reparse, “wdas_cloud_sixteenth.vdb” is a 1.5mb file, so it would be expected that Corona can reparse this quickly. However wdas_cloud.vdb is a 2.8gb file, so I think it is also expected that Corona takes longer to reparse this file when it is being moved in the IR.
There is always room for optimization, but I think this behaviour can be expected.
Cheers,
Rowan
Hi Rowan,
I don’t know how corona working but should it be reparsed each time I move it or change scattering settings? Why this not happens with geometry in the scene. For me it looks like something I wrote about in the first post - looks like vdb loaded from disk each time I move it during IR.
Anyway, I checked it with arnold active shade and everything works fine. wdas_cloud.vdb - instant response to moving volume instead of waiting 13 seconds with locked max.
So probably that’s not something to be expected.
I’ve done some further investigation and spoken with our devs, even with geometry it looks like we re-parse it with every change.
I checked the same VDB with V-Ray and the behaviour is the same.
I will update the report we have and see if there is some way this can be optimised.
Rowan
I noticed the re-parsing earlier when working with bigger VDB files. Would be great If this could be optimized somehow.
