mtlwrapper create dots
Here an image with qmc/lc all worked fine but when I have add 3 vraymtl wrapper at the scene the dots appear, I need absolutly to have the red light and others things on.
How can I do?
herer it’s real dots no? :wink:
Is there an other way to light an object without having these dots, or a param to tweak?
When you remove the wrapper and just use the regular object material, does it render ok? Also, what are the wrapper parameters?
yes indeed, when I remove the mtlwr and I let the vramtl in place all is fine.
mtlwrapper is: emitting gi=6 receive=2 all is default.
Like Jonas said me I have tested to remove the mtlwrapper and just make the object lighter in the vray object property and this work fine with the same parameters:shock:
A bug???
