hi!
I tested an animation with multiframe and single frame… the animation has some moved objects (industrial robotors)… what I found out is, that with single frame the animation flickers a lot and with multiframe the animation is nearly perfect!
Is it right that single frame greates a new IM (every frame) which is allways a little bit different to the previous frame and multiframe takes the IM from the previous frame and only changes what`s necessary!
…so I found out, that this is the thing which makes my animations flicker…
…can I fix this :evil: - problem :?:
…does anyone have an :idea:
thanks a lot
hofi
