Hopefully this is simple and possible.
How may I have the max standard multi/sub-object material, use vray materials instead of standard?
For example, if I were to add another material to the multi/sub, it uses a standard material by default causing a few extra steps, each time, to replace it with vraymaterial.
TIA
One thing that could help a tiny bit is to use Neil Blevin’s script “materialMoverCleanMeditVrayMtl” (part of the Soulburn script pack). It’s just like Reset Material Editor Slots, but fills your material editor with VRay materials, so you can quickly drag and drop a nearby one into your Multi.
