Vray 1.46.15 and Max 7
Starting scene is here http://home.comcast.net/~crubadue/vray/msc.ZIP
When using the vray scene converter the diffuse color of the standard material does not register or convert and render black.
If you drag and drop the MSO material onto the material editor the colors seem to convert. We have a case where we are populating the material editor with the MSO at conversion time and we have to turn off and then back on one of the materials in the MSO before the color values return correctly.
Best Regards,
Corey
