Multi/Sub-Object
Hi :lol:
Just wondering, if I use a multi/sub-object material with VrayMtl inside
each sub-object, does it work like several VrayMtl or because they are
inside a standard max material they will behave like standard material?
Or is it just better to make standard materials with a VrayMtlWrapper?
Guilherme
I havnt had any troubles with using vraymaterials in the multi/sub material. Correct me if Im wrong but the multi/sub material is not realy a standard material, its what ever makes up the sub materials so if you use vray materials then it will essentialy be a vray material.
-dave
Thanks Dave, I think you´re right, just wanted to be sure.
Guilherme
