Is there a way to save all render elements into a single EXR as you can in VRay?
Otherwise, can I use the Corona Image Editor to convert a CXR to a multi-channel EXR?
Thanks!
Thanks!
Should be able to save to EXR direct from Max - due to the workings of Max, you will get the main EXR with all channels, PLUS separate EXRs for each channel. Unfortunately those extra EXRs are unavoidable at the moment.
Thanks! And in the Image Editor, is there a way to convert to multichannel EXR?
