multicolored shader
hello!!! I need a shader, more or less like the doc joined, a sort of “soap bubble”, with a lot of colors, but OPAQUE… No transparencies, not a lot of reflexion (well, mostly glossiness)… Thank you for ideas!!!
Just an idea - how about the thin film shader that comes with C4D?
thank you! I’ll give it a try… but, it’s a c4d shader…it’s going to work in corona?
Yes, it’s supported. Here’s something I made a while ago.
whoww, beanzvision, I’ve downloaded your shader already.. But can’t change it for an opaque material… Well, I’m not so good (to say the less) with procedural!!
Here’s another you can test out. If you need to make it transparent you can enable opacity and reduce the Level percentage.
Material.c4d (721 KB)
