MULTILGIHT NOISE BUG IN 1.7 RC2
Hi to everyone ,
rendering a dark image there is a bug coming from the multi-light which i can try to describe as follow:
When i shot down emitting source i can still see the shape of the light on the wall from the difference of noise.
TO SEE IT YOU HAVE TO ZOOM AND CHECK ON THE TOP RIGHT CORNER OF THE IMAGE you can easy recognize the print of the ceiling spotlights.
Please see attached pictures
Hope to be usefull
Alberto
I would say this is expected, however it may be possible to improve. There are some limitations to the LightMix: https://coronarenderer.freshdesk.com/support/solutions/articles/12000017218
Here the solution could be to allow a bit more time for the rendering to make the noise go away, or simply to use denoising to blur it.
yep, this is actually because our improved light sampler (correctly) samples the other light more where it shines. Disabling the experimental light solver will work. General solution is not possible because it would slow down non-lightmix rendering. The best solution would be probably to find the light setup, then bake to scene, and re-render. Bake bugfixes are coming to v2 btw :wink:
