Multimap to change forest pack object or scatter?
Hi, I’m trying to figure out how to change my forest pack plants with multimap. I modeled the ground plane with strips so the map works fine as the texture. I just wanted to change the color of the plants now based on the multimap. Is this possible with corona scatter? Thanks!
I’m not sure if I understand the question correctly.
Can you post your scene/material setup and explain what exactly you would like to do?
I think OP is asking about things that was discussed in this topic: https://forum.corona-renderer.com/ abstract boxes in corona render #msg95767
After thinking about it more I don’t think its possible to do what I want. I wanted the ground object (that has multimap) to affect the color of the objects above it. But that’s probably not possible? I attached a concept of what I’m trying to achieve. Thanks
You could separate your different colour sections into their own objects w/ their own scatter node, then you could use the multimap as a mix.
