how can I use the the shadow layer of my multiples rendering the compositing ![]()
I get an image where the shadow are white !!!
Thanks for your help.
Best
Best
âShows the shadows (energy subtracted from the image due to shadow ray occlusion). This is the complement to the beauty pass, showing white where there are black shadows. If this pass is linearly added to the beauty pass, it negates the visible shadows. Note that currently the shadows from environment lighting are always shown, resulting in a washed-out pass in typical interior renders.â from Chaos Docs
So you need to subtract / invert the shadow pass.
I have seen that, but I am not able to have a good rest in photoshop⌠maybe Iâm doing something wrongâŚ
Donât know - youâd place the shadowpass layer in Subtract mode, or youâd invest the shadowpass layer and use any of the more usual Screen, Darken etc. type modes depending on the effect you want to achieve.
This doesnât work ![]()
Maybe I have to point that Iâm using a shadowcatcher material to have a transparent backgroundâŚ
Maybe share some images of what you are trying to accomplish? In general, if you are using the shadowcatcher, it should do the job on its own, with no need for the shadow pass at all.
What I want to achieve is being able to manage the shadows in post-process.
Depending on the background used for the image I need a darker or lighter shadowâŚ
Now Iâm doing 2 renders. One with the object without shadows or background and the second with the shadow catcher and the object casting shadow but not visible⌠This works but double my render time âŚ
Not attempted that workflow, and probably lots of ways to solve it, hereâs some thoughts that might give a solution. Someone else might have an even better idea.
Hereâs a C4D scene and a PSD. The scene has a brick plane hidden in it just so I had something to render to use as a background that would match the perspective, but can be ignored for what I was doing.
Thereâs a shadowcatching disk, which I used Rayswitch on so that it wouldnât reflect light onto the cube when rendered. It has an ID pass so I can selectively remove the cube in post. I can use the beauty pass and the cube ID mask to show just the cube without shadows. I can then either use the beauty pass, remove the cube using the ID pass as a mask, and then I get just the shadows which I can use Normal (or other variation) as a layer, and can adjust opacity to control shadow color. Or I can use the Shadows pass, do the same ID pass mask, and use Subtract mode with the layer, and then use Opacity to control the strength of the shadows (in this case, the disc doesnât really need to use the Shadowcatcher).
I didnât try and resolve the anti-aliasing question of the cube in this test (I also used white when rendering, but the saved scene has grey which should in theory be better for anti aliasing).
Both ways require just one render rather than two, and may give inspiration for how you might resolve it.
Shadowcatcher blending.zip (2.01 MB)
Oh yes, I havenât thought of using IDâs to mask parts of my scene⌠Iâll will try this path and investigate moreâŚ
Thanks for the idea.
best
So im in the same situation. I have to prepare about 20 different colors for the facade and therefore i would like to just create solids in photoshop and blend them with the different multipasses, but i also cant archiv the correct shadow behavior. So i made a couple of screenshot to show the problem. The left side od the house has to be dark as shown in the âBaseBottomLayerâ, but soon as i invert the shadow map and put it on top of the solid layer it brightens the left side. ANy suggestions how to set up my photoshop file to get the correct result?
Thank You
Christian
What mode did you use to apply the Shadow layer? You could use Subtract without inverting it. If inverted, something like Darken or Multiply should do it.
I tried both methods. do i have to apply another pass on top of it? If you like i can post the psd file.
k r
Christian
Shouldnât need anything else - with darken or multiply, not sure how it would be possible for something to get brighter ![]()
