Hi guys,
is it possible to create a black/white mask from a decal logo? In the attached image I applied the logo to a decal, I would like a mask with white text.
The only way to do something similar is to make the decal white, the rest of the scene black and do a viewport render with constant shading preview mode.
Thanks!
Hi there,
Thank you for bringing this to our attention.
I can confirm I’ve reproduced the issue.
I’ll report this to our dev team.
We’re sorry for any inconvenience.
In the meantime, an easy way to see the decal in a mask pass is by using the ID pass and setting it to use either the Object or Instance mode.
I hope this helps.
Kind regards.
(Internal ID=1062265146)
