Just did a quick test and it seems like it’s only possible to have one denoiser element in a scene? I was hoping to output two, one set to element only and the other to final result, to give me the option of denoising in post as well as making sure I have a denoised RGB pass.
Why not render with “Only generate elements” and simply denoise through the vdenoise.exe? The original files won’t go away and you’ll have both a denoised and elements-only version of your image.
Just because this guarantees I’ll need to do a post de-noise. I was hoping to denoise during the render but still have the option to do another denoise process manually if necessary only.
