Dear Vantage team
Can you please let us know if you are planning to support multiple GPUs for rendering sequences.
I mean in a way that with the same samples you render in half time if you add one additional GPU.
Thank you
We’ve supported dual gpu rendering since version 1.0. For best utilization use the “only final pass” denoiser option. Vantage uses a realtime render engine. Don’t expect it to be identical to offline engines like V-Ray GPU in every regard.
Hi, I would like to know if the 2 GPUs need to be linked using a SLI bridge in order to work. Thanks!
No, this is not necessary. This bridge would only increase the speed of data transfer between the two GPUs, which may affect the maximum achievable high framerate.
