Hi, a Quick question there is a way to set up different hdris on scene an render at the same time, so we can turn on or off using light mix on the same rendering?.
I know vray have dome light so would be simple with a dome light, but on corona, you can only put hdri inside environment slot right?..
I have the idea of put several hdri on the same image to play and choose with it later on lightmix.
You might want to read this thread: https://forum.corona-renderer.com/ Using multiple HDRI's for lighting. #msg137872
So there is no way to mix hdris using lightmix..
Not sure if works but what about using a sphere and apply Corona light material with hdri bitmap so maybe have severas spheres with different light materials applied?..
Look for their light lister, it has option to switch HDRI’s fast.
