Multiple Issues - Interactive Rendering and Tag Visibility, Export Proxy Stalling
I wanted to make you aware of a couple more issue I have encountered while working with Vray 5:
  1. While actively interactive rendering I have found that if I change the scene or camera angle in Sketchup, sometimes it will make various geometry in “tags” that are turned off and not supposed to be visible, all of a sudden become visible and part of the rendering. When I check the Tab tray in sketchup, they will still be shown as turned off and invisible. I’ve had to move this turned off geometry way outside the model and camera view (as a workaround), so it won’t frequently show up and ruin the renders. I’m using Sketchup 2021 and I know they have added folder/ tag visibility, I’m not sure if the new coding is conflicting with vray?
  2. I’ve also noticed that I am having frequent problems exporting assets to proxies where it will stall at around 85% progress. These are assets isolated in their own separate asset SketchUp file, where I am trying to manage and transfer into custom libraries for future inclusion into the asset manager. So I am copying out the files, managing linked materials/ maps, etc. I have to frequently force a close of the file during the final export to proxy and retry, sometimes multiple times for it to process. When it does export to proxy, it goes very quickly through the 85% mark on to 100% completion. I have not fully tested to figure out what is causing this. Not sure if it has anything to do with groups vs components, or some other variable in setting up the asset to be a proxy that can then be placed in a custom library and loaded separately directly from a project file. I don’t remember have such a frequent issue with this similar process in previous vray versions.
Thank you.
Hi @adamebeck
Could you please provide a step-by-step description how to reproduce the issue? Also, if you could share a sample file it would be helpful to track where the issue is.
The issue could stem from the way SketchUp structures the hierarchy of groups/components and the tags associated with them. Underlying entities could reside in different tags than the one the whole group/component is assigned and this might be the cause of the behavior.
In respect to the proxy export, could you please provide a sample file that exhibits this behavior? If this is alright, you could send us an archived copy (V-Ray > Pack Project) via email or a file-sharing service of your choice to support@chaosgroup.com (please reference this forum thread)
Hi Georgi,
Sorry for not getting back to you about this, my schedule became difficult to trouble shoot this. With regards to the hierarchy. I place everything internally on a ‘0’ layer and then use the tags to further manage those items, similarly to how I have always done.
I will keep an eye out for these issues now that I am on update 1, and try to document them if they happen again.
Thank you again for your help!
Hi adamebeck,
It seems that during interactive rendering we’re not respecting object hiding based on Tag/Layer visibility.
What I realized is the following issue:
  • Create a project with a single object
  • Add the object to a Tag
  • Store the Scene
  • Hide the Tag and store another Scene
  • Start interactive rendering in the Scene with the visible object
  • Transition to the Scene where the object is hidden (via the Tag visibility)
  • The object remains in sight
The opposite scenario works as expected - hidden Tags will become visible on Scene transition.
Is that the issue you mentioned?
As for the Proxy Mesh export:
Can you share an example model that we can use for testing?
This might be something related to the mesh topology or specific scene hierarchy configuration.
Konstantin
The issue described in my previous post has been logged as - SK-3368
Hi Konstantin,
If this happens again, I will try to better document. The opposite scenario may have been what I was experiencing. My recollection is:
  • I create everything on ‘0’ tag (now ‘untagged’)
  • I create SketchUp scenes with tag visibility managed
  • some previz items I was creating like place holders for trees, etc., were moved to a “visibility off” tag so that they would not show up but still be accessible in the model for working purposes.
  • I think it may have been (but I am not 100% sure) where I started an interactive rendering on a SketchUp scene with these tags “off” and then as soon as I moved from the current camera position and tried to orbit or move around the scene, everything would become visible.
  • This has always been my tag/layer workflow, and has never happened in previous builds. I do however use interactive rendering more now, so I can’t say for sure. But the way I had to work around this was to move the undesired geometry a set distance off the screen so the visibility while still having the geometry saved in the file, would not be an issue.
As far as the proxy mesh export: I think I noticed this on large tree files the most often, like Viz Park’s: VP Acer Rubrum v1 (Standard mat) for sketchup. I would trouble shoot the file and materials in a separate file to make a new vray proxy. And I noticed the export getting held up in that 80-90% pretty often. But it became more of a process of forcing a quite to the software and retrying to get it to go through smoothly. You can try it if you have access to those files or send me an email and I will send you a temporary drop box link.
Thanks again,
Adam
