multiple license and nodes
i need to buy two faisaas license, if i buy two 1ws+3 nodes may i use all six nodes to render with a single WS license?
Stefano Salvatore
Yes, no problem there
You will have a total of 8 licenses, from which 2 may be used as WS or nodes and 6 only as nodes. So the answer is yes, you will be able to render.
Ok, We arrive… :wink:
Stefano
Hello. Can I use rendernodes from another box-licence?
In other words, is node keys are linked to their workstaton key, or not?
yes, definitely. You can render fairSaaS jobs on box nodes, combine boxes from different orders, etc. No restrictions here.
Thanks!
I try to find an error… Some nodes does not work, and DR Server wrote:
Max install location: C:\Program Files\Autodesk\3ds Max 2014
09.04.2015 17:18:48; Max file being rendered: C:\Program Files (x86)\Corona\DrServer/drData//received_scene_3149492543.max
09.04.2015 17:18:48; Renderer: CoronaRenderer
09.04.2015 17:18:58; Error rendering frame 0: Unknown error while loading application
09.04.2015 17:18:58; Send End of Job command to Max
09.04.2015 17:18:58; Job Completed with Error(s) - see above
09.04.2015 17:18:58; Total elapsed time 396830:01:54
09.04.2015 17:19:04; Error occured while rendering job.
These are new computers without any other software, 1GB lan, Firewall off (but on/off - doesnt matter).
What is this error " Unknown error while loading application"?
This is the first thing that comes to my mind but it may be harder to diagnose:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000539776
Thank you. I go to read it all, and check up.
Hello! If i have 2 FairSaaS licenses + 10 render nodes and 5 workstations with Corona A6. How scenes from A6 rendered at nodes with Corona 1. Its the same results or i need another nodes with A6 for render it on render farm?
Sorry for my English)
And another question. How install node on render farm? I can activate or demo or FairSaaS. But how i understand, i can activate only 2 FairSaaS licenses. I need install 20 render nodes for render via deadline.
The results from A6 and 1.0 are expected to be different so it would be best to use the same version on all pcs.
You can activate as many licenses as you have.
Here is our comprehensive guide on activating Corona:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000564325
