multiple maps in direct visibility override section
since we can utilise numerous maps for environment, i guess it would be great if we could do the same thing with the background as well… because of the gamma correction in hdri images, sometimes its not possible to use the same image for environment and background . this way, we are able to use different amounts for gamma or other stuff in environment and background…
Hi. Is using a Corona Select map in the override slot not solving your problem?
