Hi again everyone.
I wish that when doing an IPR that I could select “region render” from the V-Ray frame buffer and create more than 1 area to have update. For example 3 regions or squares that the IPR works on.
Thank you.
~ Steve
Hi again everyone.
Thank you.
~ Steve
It is very likely that we will not be doing this, but you can use the render mask to select objects or regions you want to render, the regular render region in the VFB, or the “follow mouse” button in the VFB.
Okay cool, thanks Vlado ![]()
May I ask the reason you’re likely not to do this? Not enough demand? Too difficult to code in relation to the gain? Pure interest, no salt ![]()
+1, why ? it’d be such a cool feature ![]()
Dave wortley wrote a tool for this, not exactly what you want though: Vray Render Mask Maker | Max Made Easy, a blog by Dave Wortley
+1 Most definitely would use this
Same +1. always doing multiple patch renders. this would make life easier…
I second! Would be great to have this feature like fstorm does:
https://scontent.xx.fbcdn.net/v/t31.0-8/16178605\_361523667568040\_7976498814242274047\_o.jpg?oh=6341de7f183f7359fd197e3af4204d9a&oe=59149FED
This works very well in Corona. Just saying. I prefer Vray but Corona’s frame buffer is outstanding.
I’d really second the multi region render, it’s been requested for a long time and that’s exactly why Dave did a script for it, but it doesn’t cut it, it’s just not the same as having that natively supported by the renderer.
Stan
+1, it absolutely has.
Is there anything I could add to make it better?
