Multiple region render
Could we please have a possibility to mark more than 1 region in a picture for render?
Since the Vray frame buffer already contains a render-region feature then marking more than one region would be a logical next step perhaps…
Or even more cool feature would be a region of a different shape than just rectangle…
Second to this feature!
I also would like to see this!
Corona render has this and its a very useful feature and you can also turn the region off mid render and let it do the rest of the frame, but I think that’s only possible in a progressive renderer.
And those soft edges for regions Corona has is a great idea too..
I would like to resurrect this feature request. Still a great feature that I think Vray should def have.
I made a scripted solution to this a while ago.
http://www.scriptspot.com/3ds-max/scripts/vray-render-mask-maker
+1, This would be cool. Sometimes I only want to re-render certain areas. Currently I have to select region, render, repeat several times.
12 years later: Please, add multiple regions :o
While this would be nice you can do it at least two ways now. One way is to make a mask sequence in another program and use it as a render mask to render whatever areas you wish (animated as well).
The other is to use Deadline, which has this functionality built-in, and re-assembles the regions into a single file if you wish. Deadline is now free for unlimited nodes, BTW.
But still…That is a very slow and annoying workaround for a feature that exists in a sister product.
exactly! Just googled 1 min - Fstorm also has multi region render function. (engine made by 1 dev?)
+1 to bring back again this petition, for this feature
Multiple Region Render could solve a big time in specific areas
Yeah, but at least we will have AI generated materials soon #sarcasm
hahaha no need for the “sarcasm” aclaration hahaha
So many small “simple” features and QoL improvements like this and others I’ve been asking for for years and years and years I don’t think are ever going to happen. You can’t market QoL improvements like you can shiny new features like AI wankery.
With a little luck you might see the multi-region wankery this year :slight_smile:
Yessssssssssssssssssssssssssss. Peter, I think maybe I’m becoming an expert at teasing a response out of you with my extreme cynicism :twisted:
I’m pretty sure I’ll respond without it as well :sunglasses:
:frowning:
