I’ll look into that, thanks![quote=“grantwarwick, post:8, topic:48390, username:grantwarwick”]
If you’ve got the budget for it, I’d use RPManager to handle this. I can set up multiple shots in one scene and use the Object properties on the different suns to turn them on or off. Allows for multiple aspect ratios, GI settings, etc on a per shot basis as well. Then when I need to render I can select all of the shots (or some) and render them all at once. I really couldn’t work without it for some jobs.
[/quote]
