Multiple VRay Attributes (on shapes) ?
Hi everyone,
I am trying to set up different custom ID passes ( with the VRay User Color node plugged in ExtraTex)
The problem is, I can’t assign multiple VRay attributes on each objects, so I can’t make multiple passes.
Is there a workaround ?
It would be perfect If I could tell the VRay User Color node to read regular Maya Attributes..
Thank you very much,
Raphael
This is already done; in recent nightly builds, VRayUserColor and VRayUserScalar textures will recognize Maya attributes if they start with “vrayUserColor_” or “vrayUserScalar_” or “vrayUserString_”. For example, if you add a dynamic attribute with the name vrayUserScalar_test, you can then use “test” inside a VRayUserScalar texture to access it.
That was a very quick answer,
Thanks vlado, I am not using nightly at the moment but I am willing to,
Where should I ask for it ? (maybe its a silly question)
By the way I was wondering,
Does this work through proxy ?
Yes, when you create the proxy the currently set user attributes are saved in the proxy and the work as expected in the renderer.
Only in recent nightly builds though :slight_smile:
